periodic counting
Wait there is a bug. Let me fix it & post new VI.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 22
(1,638 Views)
Hi
--Ranjeet
Message 12 of 22
(1,635 Views)
Try this & let me know if you found any other bug
--Ranjeet
Message 13 of 22
(1,634 Views)
Hi Henok,
                                 Please remove break point then run this VI.
--Ranjeet
Message 14 of 22
(1,631 Views)
Hi Ranjeet,
instead of rounding up you should simply compare to "greater or equal":
Also remember: Adding small fractional numbers repeatedly (like you do) will introduce numeric errors due to floating point accuracies...
Message 15 of 22
(1,628 Views)
This is also another way to do it. I found that, you found this & both are copyright. Just kidding Smiley Very Happy.
Nice job but i dont think that this will generate numeric error becasue the precision is 1 digit only. So may be, i am not sure..
--Ranjeet
Message 16 of 22
(1,631 Views)
Hi Ranjeet,
it will generate numeric errors as you CANNOT express "0.1" with usual floating point numbers!!!
Message 17 of 22
(1,629 Views)
I see! Big lesson learned for myself here. I would watchout not to make this mistake in the future myself.
But thanks both of you guys!
I can scale up your solution, GerdW, to fit my need and that way it is perfect for my testing as I'd be able to know what to look for in my test results.
Good day!
Message 18 of 22
(1,627 Views)
I run it and worked fine for 0.1 but when I tried for precision of 0.01, it just gave one decimal point counts.
Message 19 of 22
(1,623 Views)
Hi Henok,
ever tried to adjust the (display) settings of the indicators? Just one right-click away...
Message 20 of 22
(1,620 Views)
