permutations of a 6! numerically
This is a good one...
Would be a nice coding challenge 😉   To do it nicely that is...
Message 11 of 57
(2,433 Views)
Then you're challenged! 😉
Message 12 of 57
(2,421 Views)
I built something similar to this once when I was trying to recover a lost password from an Excel spreadsheet (using ActiveX to open the spreadsheet with the new password).
It worked well, but the password was about 10 characters so I never manager to brute force it!
Will see if I can dig it up (prob not as it was at a previous employer...)
Message 13 of 57
(2,414 Views)
would really apreciate the help if you can find it 😄
Message 14 of 57
(2,410 Views)
Hm, besides that the question itself sounds a bit like: "how do i implement a brute force algorithm using LabVIEW?", i have to ask:
Is the length of the string always equal to the number of possible characters?
Norbert
Norbert
Expert: Geometry
Message 15 of 57
(2,405 Views)
Hi Norbert,
i think it don't have to. 🙂
@Norbert B wrote:
... "how do i implement a brute force algorithm using LabVIEW?", i have to ask:
Norbert
Do you think if this is the question, then we shouldn't help and he should write the code himself?? 😉
Mike
Message 16 of 57
(2,411 Views)
it is an attempt to break an encryption a friend has sent me. I suspect it is 6 characters long from a hint, i have tried 1 character to 5 by hand to no success, and i thought a program for six, seven etc... would be logical. i was then going to scan for a key word from the resultant decryption - but that bit i've already figured out how to do.
Six character will be fine for now, seven i hope can be made by expanding the program at a later date if needed.
Message 17 of 57
(2,409 Views)
its only a bit of fun, but the output will be handy for my research rather oddly!
Message 18 of 57
(2,407 Views)
Hi John,
why to change it later. The "challenge winner" should be able to handle whatever is needed!
Mike
Message 19 of 57
(2,406 Views)
i think it can be done by perhaps logical sequences,
IF A is used then character B is true for second character, if not A
Message 20 of 57
(2,391 Views)
