permutations of a 6! numerically
Ok, Mike is correct that i should not help you in working out a brute force algorithm 😉
Nevertheless, since it is a demanding request, i give you some hints:
a) Handle it in a recursive way
b) The modulo operation (Quotient&Reminder) is your friend
c) there is a reason why most algorithms do not compute all valid permutations but "roll the dice on it"......
hope this helps,
Norbert
PS: If the amount of valid elements would match the number of elements, this request could be solved fairly nicely with building all permutations on purpose. If there is no such match, rolling the dice is coming much more handy......
Norbert
Expert: Geometry
Message 21 of 57
(2,324 Views)
Hi all,
recursion in LV9 is a dream...
It's not nice, but seems to work. Open Rec_Perm_Main.vi...
Message 22 of 57
(2,322 Views)
Hi John,
the algorithm shouldn't be the problem, you can see an example from Delphi here
http://www.swissdelphicenter.ch/torry/showcode.php?id=1032.
I think the more tricky thing is to make it fast. In LabVIEW you should avoid using string arrays to store the results. Much faster is to write it directly into a file.
Mike
Message 23 of 57
(2,320 Views)
hi, can you convert for LV v8.2 please?
Message 24 of 57
(2,306 Views)
cool, can that be used in the matlab window for labview?
-> i'm not to good with the matlab window coding.
Message 25 of 57
(2,304 Views)
Hi John,
"can you convert for LV v8.2 please?"
No, it uses Recursion capability of LV2009... Time to upgrade?
That's the block diagram of the permutation VI:
18361i65075F082DF69BEE
"String in" is the string converted to an U8 array, "strings out" will be converted back in the main VI... (And the subVI is the VI itself - Recursion!)
Message 26 of 57
(2,307 Views)
ah damn, now i understand the 'its a dream' i thought you meant 'it didn't work in LV9'
no stuck with LV 8.2 for now
Message 27 of 57
(2,302 Views)
i guess it become a question of which is easier;
Build a recursive vi for lv 8.2
or
Try the sequence idea
I'm sure there is a method in the repeating and holding the already used characters using logic.
Message 28 of 57
(2,281 Views)
Hi John,
you can use the code from Gerd. The only thing you need to do is to load the VI dynamically, then it's possible with recursion.
Mike
Message 29 of 57
(2,271 Views)
sort of copy and paste? or do i need to download their softwere to see it?
how do you load dynamically - VI run settings?
Message 30 of 57
(2,263 Views)
