place the cursor in certain indicator
Hello all,
I want to ask whether anyone of you knows how to place the cursor of the mouse in certain indicator automatically when the program starts so that when I read, in my case 2D Barcode, it must be displayed in this certain indicator automatically.
Thank you in advance,
I G.
Message 1 of 26
(3,884 Views)
Do you mean mouse pointer or is it ok for you use "key focus"?
Message 2 of 26
(3,882 Views)
Message 3 of 26
(3,880 Views)
I mean the cursor (check out the attached picture) . I have no idea what "key focus" is and how to use it?
Cheers,
I G.
Message 4 of 26
(3,879 Views)
Yes, Means I guessed it right. Use can use the property node similarly for string control.
Message 5 of 26
(3,870 Views)
Accepted by igurov
Hi again,
I have tried this but nothing happens. No effect at all.
Message 6 of 26
(3,864 Views)
Solved. I was using an indicator instead of control.
Thanks!
Message 7 of 26
(3,858 Views)
Thanks!
And that doesnt mean you can mark this as accepted solution. :smileyvery-happy:
(Just kidding  :smileytongue:)
Message 8 of 26
(3,852 Views)
🙂 i did it by mistake
Message 9 of 26
(3,850 Views)
:smileyhappy: i did it by mistake
No Probs. Glad that your problem got solved. I was just kidding. I have seen this happening a lot of times in this forum. :smileywink:
Message 10 of 26
(3,847 Views)
