please convert my files from 8.0.1 to 7.0
Can anyone help me convert these files to 7.0?  Greatly appreciated it if you could help me.  Thanks.
Message 1 of 9
(3,857 Views)
Accepted by mindycheng
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 9
(3,841 Views)
can u tell how to convert the lv program 8.6 to lv 7...... pls if u have any software or program post it here here ...
N. Srinivasan
Message 3 of 9
(3,756 Views)
see here
Message 4 of 9
(3,752 Views)
Thank for that table to know about the saving procedure....  🙂
N. Srinivasan
Message 5 of 9
(3,740 Views)
Can u convert my vi to labview 7.0 version
N. Srinivasan
Message 6 of 9
(3,678 Views)
can any one convert above file to labview 7.0 version !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Smiley Indifferent
N. Srinivasan
Message 7 of 9
(3,670 Views)
You should mention that to convert this the person will need the database toolkit installed. Since the original thread is marked "solved" it might be a good idea to start a new thread, since many won't look at a solved problem.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 8 of 9
(3,659 Views)
Message 9 of 9
(3,642 Views)
