plots legend arrangement
Hi all,
I am design my software front panel.  I have a problem about plots legend. The defaut arrangement is in vertical direction as attachment shown. I want to arrange the plots legend in horizontal direction. I searched  Labview help and did not find the solution. Would you give me some clue? Thanks in advance!
Lang.D
帖子被Mechtest在 03-03-2010 07:09 PM
时编辑过了
(4,488 Views)
Accepted by Mechtest
Placae the Graph or chart on the front panel and then pull the plot legend horizontally....(when you click on the plot legend and drag the highlighted part of the legend horizontally so that multiple plot legends can be seen.Pull them vertically if you want to see them in vertical position)
Guru
Regards
Guru (CLA)
(4,468 Views)
