populate updatable drop down list based on files in the folder path
The simplest way I can think of is to use an event structure, so that when the value of "Folder Name" changes it will trigger an event to populate the file selection dropdown.
Message 11 of 17
(1,557 Views)
Thank you, I manage to do this using the event structure, the response of the toggle switch inside the while loop becomes very slow, any idea why? event 1.JPG
Message 12 of 17
(1,553 Views)
Show us the code and not pictures and we'll tell you.  You wouldn't take screenshots of notepad would you?  For the same reason post the VIs, or Snippets which are executable code embedded in the image.
Message 13 of 17
(1,543 Views)
I attached the code below, the two toggle switch is linked together, when the program is running, try to turn off the TO Static button, it should pop-up a message, but it takes looooong time. Thank you bro.
Message 14 of 17
(1,539 Views)
That is because you are waiting literally forever for an event in your event structure to be initiated.  Data Flow 101: a loop cannot iterate until everything in it has completed.  Your buttons should have their own event case and you should move all of the related code into that event case.
Message 15 of 17
(1,535 Views)
Hi Xiao,
your event structure is blocking the loop from iterating.
So the buttons will be checked very seldomly…
Some notes on your VI:
- THINK DATAFLOW!
- Reduce the local variable usage. (A lot!)
- There are race conditions…
- There is a lot of Rube-Goldberg in your code…
- Why do you need to calc "BoolValue OR NOT(BoolValue)"? Do you know the result of this operation???
Message 16 of 17
(1,533 Views)
I think the easiest way is to replace the path constant with path control, leave the rest of code as it is, it will solve the problem, and it works fine.
Message 17 of 17
(1,506 Views)
