precision of formula node?
@Darin.K wrote:
johnsold wrote: Edit: Hey, If we help their retirement funds, does that give us better chances of some day catching up with their post counts?
Lynn
Your logic is escaping me here.  Retirement=More free time=Fewer posts to the forum? Smiley Happy
I'm hoping post count is stored as a U16- the only dang way I'm likely to come close- even ploting on a log scale!
Message 11 of 14
(976 Views)
Hello
I am trying to generate a sinus signal (and others) by getting an ouput array (with a formula node) that sholud fit the maximal resolution of my card (if I am not wrong the resolution is 20V/2**16 =>305uV).
The problem is that I get only 5 decimals on the output (float32). Why?
-Labview 2013
-PCI X 6321
Message 12 of 14
(930 Views)
I can't open your VI because it is too new.
But I'm going to guess that you the 5 decimals you are seeing is because that is the display format of your indicator.  Try changing the display format to show more decimals.
Message 13 of 14
(916 Views)
Hello
Yes, you are right. Sorry for the stupid question.
Thanks.
Message 14 of 14
(904 Views)
