You should be using NIdaqMX base, not daq base. The measurement
and automation will probably recognize the daq card, but you really
cant configure it, in my experience, through the autmation
wizard. You can try using the basic NI logger program that comes
with the 6008 and basemx, or you can look at the program below to see a
very simple example to see how to read from the 6008.
Actually, if you are using Windows O/S then you should program your USB-6008 using NI-DAQmx 8.0. Instructions for configuring your device for use with NI-DAQmx are available in this KB. After making this change you may want to convert any NI-DAQmx Base VIs to NI-DAQmx using the NI-DAQmx Base to NI-DAQmx Conversion Utility. You can also use any supported LabVIEW examples from the NI Example Finder (Help>>Find Examples) by browsing to Hardware Input and Output>>DAQmx.
The NI-DAQmx controls for LabVIEW only work with NI-DAQmx. The information is true whether you are using Windows, Linux, or Mac OSX.
