Showing results forĀ
Search instead forĀ
Did you mean:Ā
pulse width measurement
Try setting up your sample clock before starting your read task.  This is how you can setup the sample rate (and therefore get a dt).
Message 21 of 29
(1,740 Views)
Dear Crossrulz!
Thanks for your help!
i can get result, but i thinks that is not correct! i show u!
u can see, thanks so much!
Message 22 of 29
(1,739 Views)
hii Crossrulz
how to up sample clock? i had "number of samples" and "timeouts" and some things!
u can see in my program!
help me about that!
Message 23 of 29
(1,738 Views)
Use the DAQmx Timing VI.
Message 24 of 29
(1,736 Views)
Crossrulz
i know about Timing VI, but i mean how about somes thinks
"samples of channel" = ?
"samples of mode" = ?
rate =?
and somethings?
thanks for your help!
Message 25 of 29
(1,734 Views)
Crossrulz, i try to use DAQmx Timing VI, but they give one error "200557"
hic hic
Message 26 of 29
(1,731 Views)
@29071985 wrote:
Crossrulz
rate =?
and somethings?
The mode should be continuous.  The rate is how many samples per second to take.  You can leave everything else unwired.
Message 27 of 29
(1,729 Views)
Dear Crossrulz!
I try to do follow you!
but result is the same! hic hic
help me!
Message 28 of 29
(1,711 Views)
HiiCrossrulz!
I try to used QAQmx Timing with rate, sample mode, samples per channel with difference value in many time! But i never got result, i did not know what did i wrong?
can u help me about that!
thanks!
Message 29 of 29
(1,695 Views)
