question about Conditional Disable Symbols
Accepted by NemoChen
@NemoChen wrote:
Does  it make sense?
No, it does not make sense. Conditional Disable Structure is a set of instructions for the LV compiler. So changing symbols REQUIRES a recompile of the VI. If you fail to do this, changing symbols will not affect VI execution.
What you are looking for is a simple case structure and passing a parameter "as symbol" to select which case you want to execute.
Norbert
Expert: Geometry
Message 11 of 13
(1,236 Views)
Yes, you just gave me another easy way to solve it.
thank you!
Message 12 of 13
(1,234 Views)
Another, "better" option (but requires more LV knowledge) would be implementation of a class based abstration layer.
TS nowadays can directly call LV dynamic dispatches, so a class based abstraction replaces the case structure and the additional parameter.
Norbert
Expert: Geometry
Message 13 of 13
(1,217 Views)
