question about Conditional Disable Symbols
I found a problem when Im using the 'Conditional Disable Symbols'.
I have a labview project which I set a Symbols 'debug mode', which I guess lots of engineer will use it similar when debug VI.
all works fine.
My question is on this:
Im not 100% sure but looks like when i want switch the mode, if i just only change symbol value and save the project. it will not take effect to the real VIs which will call the releated condition structure. Instead I have to open all VIs related before change the symbol, after change the symbol just save all (project property and VIs)
In the other word if I do not open VI but only change project property, then the change will not happen on VIs.
Is that the truth? If I have many VI so each time change the symbol, I have to open all VIs and save?
Thanks!
Message 1 of 13
(6,600 Views)
While I do not know the answer (never having used Conditional Disables), how hard is it for you to do a test, as you have them already implemented?  Before you make the change, go into an affected VI and get it to "announce" (by setting an indicator, perhaps) which "version" it is using.  Then make the change, close and re-open the Project, and run your "sentinel" VI, which will tell you if it has been changed or not.  Then come back here and provide the Solution (be sure to mark your answer as the Solution to help the next Forum user who has the same Question).
Bob Schor
Message 2 of 13
(6,540 Views)
Bob Schor
I never used them either, until I created a project that I wanted to both deploy to my RPi3 and be buildable into a Windows executable.  Interesting stuff going on with handling front panel buttons in the exectuable and using physical buttons on the RPi3.
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(6,519 Views)
I used it from time to time to have a simulation mode or to enable/disable some hardware. I just hit the project save all button after changing a symbol value and it works fine.
Ben64
Message 4 of 13
(6,509 Views)
NemoChen>> That is not my experience of using Conditional Disable Symbols. The symbols are a property of the project.
By the way, if you are building executables and are using Conditional Disable Symbols, a neat trick is setting the Conditional Disable Symbols programmatically and using Pre Build Action to call a vi and change the symbols to the correct value for the build.
Message 5 of 13
(6,482 Views)
Thank you all for your coments.
My situation is I have a labview project, which I set the condition symbols. And I use test stand to call individal VIs in that project. I did not buid VI to excutable.
I assume when i change the property of the project, then the change will auto take effect to all VIs in that project.
I need more trial to check all this factor's relation.
Thank you!
Nemo
Message 6 of 13
(6,477 Views)
this is what i expect but...
I'm using test stand to call VI, seems other changes in VI take effect but the symbol not. I'll investigate it more.
Thanks!
Nemo
Message 7 of 13
(6,474 Views)
@NemoChen wrote:
I'm using test stand to call VI...
Are you including the project in the call of the VI in TestStand?  If not, my guess is the VI (which would be opened outside of any project context if you did not specify) will just use whatever symbol it used when it was last opened and compiled.
Message 8 of 13
(6,446 Views)
Hi Crossrulz,
Do you mean the 'Project path' in 'Module' of step settings?
I just leave blank.
So it's better include this item?
Message 9 of 13
(6,420 Views)
HI,
I just had some time repeat this problem and let me simplify it.
first of all i am using teststand call vi.
i have vi project, where i put the symbols on. and i have some vis in this project, which using the symbols inside (conditional disable structure)
what i can repeat are, 1, in labview window, i close all VIs, open only the VI project exploer. then i change the symbols by right click project and save the project.
then switch to teststand run sequence call VI which be included in that VI project. i can definitly say the symbol change does not take effect on the calling.
2, in labview, open project and VI front window. change symbols as normal. then save all ( actually if check at the 'list unsaved changes. it show VI recompiled. Although i did nothing on the specific VI, only open it.) and switch to teststand call vi again. that works.
What I simply want is, change the symbols only on project, save, then I can use test stand call all VIs. No need check each seperate VIs.
Does  it make sense?
Message 10 of 13
(6,413 Views)
