random numbers
How to generate random binary number "16 bits" ?
Message 1 of 10
(8,301 Views)
Hi Marina,
you use RandomNumber from numerics palette. Then you scale the number to your "16 bits" range as needed…
Message 2 of 10
(8,297 Views)
But it cannot be binary .. I changed it to be unsigned 16 bit inside a loop with constant counter = 15 to be looped 16 times but I got 4 bits I don't know why ! Any Idea ?
Message 3 of 10
(8,293 Views)
Hi Marina,
when you run a loop 16 times and only get 4 bits you definitely made something wrong.
It would help when you attach your VI…
Message 4 of 10
(8,287 Views)
here is the VI
Message 5 of 10
(8,279 Views)
Accepted by MarinaNashaat
Message 6 of 10
(8,271 Views)
If you are asking to have a random unsigned 16bit integer, this will do the trick
Message 7 of 10
(8,263 Views)
Thank you
Message 8 of 10
(8,260 Views)
Thank you
Message 9 of 10
(8,259 Views)
Bowen's example will have a slight bias towards zero in any give bit because when the random number is exactly 0.5, it will round down to zero instead of up to 1.  (random number range is 0 to .99999.....)
Awang's example is not very good either, actually worse, because it will have a bias away from 0 and 65535 happening about 1/2 as often as the other numbers because the way it rounds to nearest.
The proper implementation is to multiply by 65536, then round down.
Message 10 of 10
(8,243 Views)
