reading values from an array element and sending a digital output to a designated channel depending on the value read from the array
hi everyone
could anybody help me before i pull out my hair. Here is my problem#
I am reading 3 values from a 3 element array i.e. 1,2,3 . these values are then compared to a constant value , example if the first array element is 1 and it satisfies the comparison condition then send a digital output to that designated channel on the DAQ
I want to be able to send a value from a array to its corresponding comparison and then onto its designated channel on the DAQ, the whole point of this is due to the fact the array element will not always read in the value 1,2,3 i.e. could be 2,3,1
below is a the vi I have so far
if somebody could help it would be much appreciated
all the best
mark
(4,849 Views)
Accepted by Tomber
Take some time to explore the many examples included with LabVIEW that cover the fundamentals.
 -  array indexing
 - reading a spreadsheet file
(4,820 Views)
hi jeff
that is very similar to what i done , i eventually sorted it out but again i would like to thank you for taking the time to reply.
all the best
Mark
(4,806 Views)
Mark,
Why are using express Vi's to do simple comparisons?
Alan
(4,779 Views)
