real time help and install
i did reinstall the USB create thing many times
so with that in mind, how do I solve the "corrupt software?"
Message 21 of 43
(1,395 Views)
Re-install Windows.
- tbob
Inventor of the WORM Global
Message 22 of 43
(1,381 Views)
ok now funny thing is i followed your steps, still same message
now what? so far you told me to reinstall windows, did that, still the same problem and issue, another way to solve this?
Message 23 of 43
(1,370 Views)
Is this a PXI RT Target?  The following two KnowledgeBase articles may be helpful.
Diagnosing Hard Drive Failures for PXI and VXI
http://digital.ni.com/public.nsf/allkb/E15AAB42FD3B625E86257111005E3CFF?OpenDocument
Why Am I Unable to Format My PXI-RT Controller from a Desktop PC Utility USB Drive?
http://digital.ni.com/public.nsf/allkb/21B9C3C367941A2B862575FA004E3ED7?OpenDocument
Best,
Chris LS
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 24 of 43
(1,356 Views)
both the computers that i am using, mother and target are both desktops, again, on the target computer it said gave that error message that is described in the previous entries of the posts
i reformatted the hard drive because tbob told me too. so what are my options now i am really desperate!
Message 25 of 43
(1,353 Views)
Are you trying to install the LabVIEW Real Time O/S to this PC?  Where do you see this corrup disk error?  How are you formatting the disk at the moment?
Best,
Chris LS
Message 26 of 43
(1,341 Views)
On which computer are you getting the error booting from hard disk message.  This message can only have three causes:  corrupt software (fixed by re-install - this evidently is not the case), a bad hard drive (you probably could not even reinstall anything if the hard drive is bad), or a bad motherboard.  Is the problem on your RT system or your development system?  Which RT O/S are you using.  Which windows development O/S are you using?
- tbob
Message 27 of 43
(1,337 Views)
Best,
Chris LS
i am trying to only install using the USB create, i am seeing this message on the target computer, i am using the usb to format using the usbcreate exe thing
Message 28 of 43
(1,332 Views)
i am getting the error on the TARGET computer, the problem in on my RT dedicated computer, i am using 9.0 RT OS, windows development..hmm..XP?
Message 29 of 43
(1,328 Views)
What is USB Create?  Does that re-install the real time operating system on the target computer?
- tbob
Message 30 of 43
(1,326 Views)
