real time help and install
The Real-Time module is a seperate product from the LabVIEW Development System however the files for the LabVIEW Real-Time Module should be on your LabVIEW platform DVD 1.  When running the installer, choose the custom install option and be sure to choose the LabVIEW 2009 Real-Time Module.  If you have a license associated with your serial number the module will activate after install.
Which LabVIEW 2009 Platform DVD Is My LabVIEW Module or Toolkit on?
http://digital.ni.com/public.nsf/allkb/1F515CFAF453A9BF8625768100565A3C?OpenDocument
Chris LS
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 11 of 43
(1,567 Views)
At school we have the academic site licence 2009 fall, guessing it does not have it here? If so we have to buy it seperately?
Message 12 of 43
(1,557 Views)
Accepted by topic author Mechatronics MAN
It is not included in the core components Academic Site License however it is an optional addition if you have the "Control and Embedded Systems Option".  If so, it will be on the DVD labeled "Controls and Embedded Systems".  Check with your software administrators to see if your school has this component.
Best of luck!
Chris LS
Message 13 of 43
(1,541 Views)
thanks, that is the answer that I am looking for
Message 14 of 43
(1,532 Views)
now I have a new problem
i had labview installed, but now i moved the computer, it will have a new location (ie new IP) but now I get this error:
error booting from hard disk
please help
Message 15 of 43
(1,482 Views)
Sounds like you crashed the hard drive.  I hope you didn't move it while it was running.  If you did, then you certainly crashed the hard drive.  The only thing you can do is to replace the hard drive and re-install everything.
- tbob
Inventor of the WORM Global
Message 16 of 43
(1,477 Views)
what do you mean by "move it"?
Message 17 of 43
(1,469 Views)
You said you moved the computer.  Quote:
"now I have a new problem
i had labview installed, but now i moved the computer..."
If you moved the computer while it was running, and the hard drive was being accessed, chances are you damaged the hard drive.  that is why it will not boot anymore.  Before moving a computer, you should shut it down.  This will park the hard drive heads then power down.  With the heads parked, there is little chance that the disk will be damaged.  Without parking, the heads could bounce or hit the hard drive platter causing a crash.
- tbob
Message 18 of 43
(1,463 Views)
no what i meant was i moved the computer when it was off to another room, i had to redo the usb create thing. so i moved the computer redid the process as i was told from NI and everything seems to work but that message came up "error ...." so know of an alternative method? i doubt my hard drive is broken...
Message 19 of 43
(1,459 Views)
If you have an error booting from your hard disk, then the disk is either broken or the boot software is corrupt.  You don't even get your Windows OS to come up.  Try re-installing your windows operating system.  I would perform a disk check before installing anything.
- tbob
Message 20 of 43
(1,452 Views)
