redpitaya-Synchronised one pulse signal generation and acquisition
Hi, I'm new working with redpitaya and labview.
I' ve been trying to get the example " Synchronised one pulse signal generation and acquisition" with labview worked. But I have some problems.
Fisly, when I downloaded it, some of the varibles where the wrong type, so connection couldn't be done ( 1-picture). So I use a converter block ( from string to number) in order to solve this problem, as it wan't working I changed directly two of the inputs from string to number and I kept the conversion of the rest of variables string (2-picture).
I wasn't getting any error, but the example wasn't working properly. When I play run, it only resgisted noise, but not the signal It was been created (3- picture). I changed the paramethers ( chanel I was using, amplitude, frecuency, the form of the signal itself)
To check that the wire and the RF input and output was OK I tried to modify the signal, putting it on my hand, and the noise signal change, but It was still noise (4-picture). I have tried every input and output, but I got always the same signal: noise.
To conclude: I can't make this example works.
Futhermore, I have a question about this example, labview and Redpitaya libraries: How can I change from input 1 to input 2 and from output 1 to output 2, because I only see the option chanel 1 and chanel 2, but it doesn't say which combination of input and output is. and I can't find the block to change inputs and outputs
If someone got the same problem,  how did you solve it?
Thanks in advance!!
(4,680 Views)
Accepted by lucialucilu
The inputs you "fixed" aren't numbers, it looks like they are channel names. The representation changed some time ago but this is an old example.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,663 Views)
