regarding array
Hello Everyone, Kindly anyone help me how to insert number in an 1d Array.
(1,998 Views)
Use the Insert Into Array function.
CTRL+Space, type Insert Into Array, or go to the Array palette:
(1,993 Views)
You need to provide significantly more detail:
  • Are you trying to insert a number in edit mode into an array control or diagram constant?
  • Are you trying to do this at runtime?
  • Where does the array come from? Where does the number come from? Where does the output go?
  • Are you trying to insert that number into an arbitrary location, moving all existing higher elements up?
  • Are you trying to append or prepend that number to the 1D array (i.e. insert at the end or beginning)?
  • Are you trying to replace an existing value with a new value, keeping the array size constant?
  • Note that if you do this repeatedly, you should keep the array in a shift register or feedback node. Are you familiar with these?
You will get significantly more precise answers if you would attach a very simple VI so we can tell what you are trying to do.
(1,956 Views)
Use the free online tutorials. This is pretty basic.
(1,949 Views)
