regexp to capture numbers
i have lines containing numbers looking like this : \s\s\s1025.205\s\s\s-0.002\s\s\s520.125\s\s\s0.001\s\s\s\s
number of \s to separate is not constant
which expression can i use to obtain numbers between "\s"
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 1 of 8
(3,689 Views)
This worked for me
Tim
GHSP
Message 2 of 8
(3,685 Views)
thanks
how can i add the sign  ?
Tinnitus
Message 3 of 8
(3,682 Views)
@tinnitus wrote:
thanks
Tinnitus
I do not understand your question?
Do you just want to add it to the result? If so just concatinat the result and the ?
Tim
GHSP
Message 4 of 8
(3,680 Views)
Sorry,
with this regexp did you recover the minus of  -0.002 for exemple ?
Message 5 of 8
(3,676 Views)
Accepted by tinnitus
This one works sorry I did not notice that.
Tim
GHSP
Message 6 of 8
(3,666 Views)
You can add [\+\-]? in front of aeastet first regex, alternate regex solution is [\+\-]?\d+\.\d+
Ben64
Message 7 of 8
(3,662 Views)
Presuming that you would want to perform some mathematical operations on the values, you may want to consider using "Scan from String"
Message 8 of 8
(3,652 Views)
