regular expression for finding anything which isn't a defined sequence
Accepted by rik_aspinall
Try this, I hope this help you. If you want another word, change hello by Hello or any other.
Message 11 of 14
(1,454 Views)
As I say folks I'm aware that there are many ways around this problem. I am asking specifically for help in writing a regular expression such that the same result is achieved.
Message 12 of 14
(1,435 Views)
You need to be more specific, the match pattern vi has no boolean output that can return TRUE or FALSE.
I guess input is the string input of the match pattern vi. What is Match, the regular expression input? And what is Match?
Ben64
Message 13 of 14
(1,422 Views)
Unfortunatly you used Match Pattern.vi which only accomodate a limited set of regular expressions. You need to use Match Regular Expression.vi to be able to do what you want with a regex. A variation of the regex in AYanez post should do the trick.
Ben64
Message 14 of 14
(1,399 Views)
