regular expression to remove trailing zeros
I need a regular expression to remove trailing zeros after the decimal point. I tried (?<=\.\d+?)0+(?=\D|$) but I get a error about look behind not a fixed length or something like that. I am not a regex expert and I was wondering just how to do this with regular expression or some other way.
Message 1 of 16
(15,781 Views)
Hi
did you try "%#_6g"? where the 6 is the significant digits. you can change it to your need.
try this "%#.6g" if you want 6 digits of precision.
how are you trrying to set the format? using a property node? if you want to do it manually on a control object, you can set it in the properties dialog box of the control.
Regards
Freelance_LV
TestAutomation Consultant
Message 2 of 16
(15,777 Views)
Check out this website:
www.regular-expressions.info
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 16
(15,757 Views)
Accepted by Z.K.
Z.K. wrote:
[...] or some other way.
I tried and I tried but I couldn't crack it with one regular expression, so I took the easy way out.  The first Match Pattern finds the decimal point and the second one clears trailing zeros from the rest.  It doesn't discriminate between numbers and everything else, though.
Jim
Message 4 of 16
(15,745 Views)
Smiley Surprised
Well, if Jim can't crack it with a regex, abandon all hope ye who entereth here.
Smiley Surprised
Im more of the opinion that a Scan from string to DBL + formating the indicator's display is the better approach though.
Message 5 of 16
(15,737 Views)
Jim,
I checked it and it actually works with just one regular expression, 0*$ or 0+$. Before substring is the number without trailing zeros.
Message 6 of 16
(15,717 Views)
@Sergey Kolbunov wrote:
Jim,
If you can GUARANTEE that a decimal point is in the input string it would work, but try it with an input string of "1000" (without the quotes)
Rod.
Message 7 of 16
(15,708 Views)
@Jeff Bohrer wrote:
Smiley Surprised
Smiley Surprised
Darin.K hasn't chimed in.  His opinion is a much better guide as to whether it's solveable or not.
Jim
Message 8 of 16
(15,681 Views)
Well, since you asked my quick answer is to not look at which parts to grab from the string, but rather which parts to eliminate.  I would go with a Search & Replace:
My usual taste is to leave at least one zero after the radix point (ie. 1000.00000 becomes 1000.0), so what I show here uses a minimum width.  The example as written gives a minimum width of three digits after the radix point (if the original number has more than three).  You can change the number 3 to be any minimum width you like, or remove the quantifier for a min width of 1. (\d{1,3}+ becomes \d).
Edit:  Added bonus, as you see it will do the deed to multiple numbers in a string without a loop.
Edit 2:  Would I really do this using a Regex, maybe not, but the point here is that it could be done.
Message 9 of 16
(15,673 Views)
@jcarmody wrote:
@Jeff Bohrer wrote:
Smiley Surprised
Smiley Surprised
Now that Dr K has chimed in... (and solved it without a regex) I'll stand by my statement of "abandon all hope".  some other method may work.  a Regex will not be the best solution in this case.
Message 10 of 16
(15,646 Views)
