report generation, 2 own excel charts
Hello everybody,
I tried two 2D Arrays insert in two charts, each 2D Array in its own chart. The problem is in the second chart are the two 2D Arrays.
You can see it in the attachments.
I hope anybody has a solution.
Many thanks in advance for your help
zäpfle
LV2010
(3,139 Views)
Zapfle,
Can you understand what you are trying to do?
I will be able to help you better if you save your VIs in 8.5
Prashanth N
(3,134 Views)
I think my explanation isn't the best. Maybe the attached VI (LV8.5) explains it.
I have two 2D Arrays with data. The first 2D Array (Profil HOR) should insert in the first chart and only the second 2D Array (Profil VER) should insert in the second chart.
zäpfle
(3,131 Views)
Accepted by zäpfle
I think I didn't prepared the 2D Array (Profil Ver) right and therefor in the second chart are two linies.
(3,127 Views)
Hi Zapfle,
I think the problem is because you are wiring the "report out" of the first graph into the "report in" of the seond graph.
Try to use different reports for each graph. You should see the correct behaviour.
Prashanth N
(3,124 Views)
Oh yes!
I see it too.
Glad you found the problem.
Regards
Prashanth N
(3,123 Views)
