report generation
Just one quick suggestion.
I'm finisching my application, and I want to print out a very simple report including some of the objects on the front panel.
My target is to print out a PDF with some graphs and data as they are at the moment of the press of the PRINT button.
I've seen LV offers many way for creating a report: DIadem, report generation, express VIs.. Can you please suggest me which one I should use for my purpose?
Thanks!
(3,382 Views)
Accepted by Stefano Moret
Hi Stefano,
i think the report generation is a good tool for you. After you have your report you can print it with a pdf creator.
Mike
(3,357 Views)
can u send me the report generation program.. in my applicatin i want to generate the report for the pin status... in the .pdf format.... .. im waiting for ur reply...............
N. Srinivasan
(3,257 Views)
