require login window vi from login panel vi
vi which was done in LV 4.0 which is not opening in labview 7.0. when i tried opening in LV 4.0 i was able to se the front panel but not the block diagram.
i need to replace the same login_window.vi with block diagram.
I didnot understand the function of vi and unable to start building the same vi.
plz give your suggestion and help me to build login_window_vi it is a subvi of login_panel.vi which i am attached as a zip file in this login_panel.vi
(2,782 Views)
I'm going to give you basically the same answer I gave you here. A VI without a block diagram cannot be converted to a newer version since it's "source code" is missing and there is no way to retrieve the block diagram once it's been deleted. The VI without a block diagram must have been part of some add-on from NI or a thir party or they were developed internally by someone who then did a save without block diagrams. Obviously the llbs with the VIs exist somewhere on your system but you didn't include them in your attachment. Your only hope is to determine the source of these VIs and hope that there's an u
pdate available. See if there's anything in the documentation of the VIs that will tell you where they came from. Post the llbs that contain the diagramless VIs and maybe someone will recognize them.
(2,782 Views)
here by i am posting the llbs contain the diagramless
VIs.
Dear all, kindly recongnize and suggest me to build with block diagram
(2,782 Views)
