reset control
How can I reset controls to default when I stop running the program (with abort execution or stop button on front panel)?
(6,412 Views)
For starters, NEVER ABORT.  If you are using a statemachine you should have an exit state that will allow you to handle reseting controls.  You could do this using something like this code here:
This is an invoke method for the VI, found on the Application Control pallete.
Message Edited by jmcbee on 03-13-2009 11:36 AM
(6,411 Views)
I cant find it, Im sorry. Can you help me once again how to find and how to connect?
(6,398 Views)
Accepted by musclelab
No Problem.  Take a look at these images and let me know if you still have any questions.
Message Edited by jmcbee on 03-13-2009 12:14 PM
(6,388 Views)
Thanks a lot !
(6,370 Views)
This has helped me also. Thank you.
(5,465 Views)
thanks for the help
(5,445 Views)
