retrieve value from array
Hello everybody,
I want retrieve value from an array. but i can not do it.
on a document, i put many value and i would like tu use theses value as parameters. I can retrieve document but not recover the values from array.
Do you have an idea ?
Message 1 of 13
(6,269 Views)
Hi treti,
maybe you should use a different instance of the ReadDelimitedFile function to read in numeric values instead of an array of strings?
Message 2 of 13
(6,235 Views)
Thanks for your answer,
what do you advise? if I use something else as a function I will not be able to retrieve the document?
Have a nice day
Message 3 of 13
(6,228 Views)
Have a nice day
My ESP isn't working very well today, so I can't see what the document that you didn't attach looks like so that we can help you to fix the broken wire in the vi that you also did not attach.
Message 4 of 13
(6,221 Views)
this is my VI,
Thanks you
Message 5 of 13
(6,219 Views)
Accepted by Mat1987
Hi treti,
when you want to read numbers you should read numbers - and not strings!
Message 6 of 13
(6,197 Views)
Thanks!
I didn’t pay attention, so much for myself.
However, I cannot get the value of the indices 1 2 3 ... in my document. I only have the index 0. Have you an idea ?
Thanks you !
have a nice day
Message 7 of 13
(6,179 Views)
Hi treti,
How should we say when you don't upload your CSV file?
Message 8 of 13
(6,173 Views)
yes, this is my document.
is an example, in the futur, there will be a lot of value.
must it have a special separation? excuse me for theses question, I'am a beginner in Labview.
Thanks you so mutch for your time
Message 9 of 13
(6,168 Views)
Hi treti,
works fine for me:
(Using LV2011, so the older icon for the ReadSpreadsheetFile function.)
Message 10 of 13
(6,158 Views)
