rslinx with labview
hi
Can i connect an AB SLC 500(5/03)plc  through rslinx opc server with labview 7.1. i´m using rs232 df1 protocol and i want to use datasocket read and write vi´s.  Where can i find vi examples to read data from plc.
thanks.
(4,208 Views)
(4,193 Views)
hi, thanks for reply.
i`ve read the info from the link, but i have a couple of questions.
1. can i get an read data if i dón´t have server explorer, lookout and dsc module?
2. is there any vi example showing how to write to the register?
3.i have to repeat step 16 to add registers to read and registers to write, the attributes are the some for both?
thanks for your attention
(4,176 Views)
I haven't tried it, but I think this is what you are looking for...
http://decibel.ni.com/content/docs/DOC-4065
Mike
(4,166 Views)
hi,
can i use that vi´s with rs232 df1 protocol(i need to use) or its only for ethernet connection?
thanks for response
(4,159 Views)
I thought you could from any connection, but now that I look at them, I guess it's only ethernet, and they are locked from editing.
I found some a while back while googling, but can't find the links to them right now - but I do remember that I was able to edit them and change the com, because I also wanted to use them with a 5/03.
Mike
(4,157 Views)
thanks for information, i solved the problem
(3,975 Views)
