write data to rslinx opc server
hi, is there any example of how to do that, or someone have a good advice to do that. i want to activate an output in plc slc500 ,is it posible or i have to write the data a variable(n7:0 for example)
i´ll thank you a lot.
(3,749 Views)
Have you tried the info from http://zone.ni.com/devzone/cda/tut/p/id/4626
Brian K.
(3,744 Views)
IF I DONT HAVE LOOKOUT I CAN DO IT? IHAVE LABVIEW 8.6, DSC 8.6 AND LINX GATEWAY.
IS THERE ANY OTHER TUTORIAL THAT EXPLAIN HOW TO PUT AND CONTROL TAGS IN LABVIEW
THANKS FOR RESPONSE
(3,718 Views)
I CAN READ THE INPUTS FROM THE PLC IN LABVIEW, BUT HOW CAN ACTIVATE AN OUTPUT FROM LABVIEW TO THE PLC.?
(3,714 Views)
Thanks for all help, i found a way to do it and the problem was solved.
(3,571 Views)
