run labview over remote desktop connection
I added the screen shots to show this a little better. I'm going home defeated for the day 😞    That is also another concern is if I develop it this way then the executeable will have to stay on that server also. Right????  I am not sure if I try and use some sort of virtual instrument when developing that it is going to respond the same as the real instrument. DEFEATED
Message 11 of 15
(1,392 Views)
It appears that the test station has a third-party GPIB controller. Is this correct?
Message 12 of 15
(1,378 Views)
Correct, It has a usb to gpib controller from agilent. Thanks for the help!!
Message 13 of 15
(1,348 Views)
Then in that case I don't know if the VISA Remote will work. There are a few KB articles discussing using third-part controllers with Max, such as these:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHcyCAG&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHh0CAG&l=en-US
but I don't know of how much help they will be. You may want to try updating to the latest version of VISA if you don't have it. I suspect though, that if you were to use a National Instruments GPIB interface you probably wouldn't have an issue.
Message 14 of 15
(1,344 Views)
Discussion moved here.
Message 15 of 15
(1,326 Views)
