run time engine 2011 error
That message seems to point to a different problem then the "missing plugin" that Firefox is referring to.  I wonder if it is a more accurate message?
Do you have the VI running on the server computer?  Do you have web access enabled on that computer?
Message 21 of 22
(472 Views)
I have opened the VI file in labview, configured the web server, selected the vi in web publishing tool, saved to disc, clicked connect and ok.
Message 22 of 22
(466 Views)
