sample data is not retained when I save VI to desktop
The sample data is not retained when I save the VI to the desktop. its a 5 element input array containing 1, -1, 3, 6, 2. I am trying to create two indicators that will hold the total number of oveshoot/undershoot values. In this case it will be 1 and 1.
Kadeel
(3,293 Views)
Accepted by Kadeel
Duplicate post.
Please stop creating separate posts again and again. You are creating very much noise in this forum. Smiley Mad People will get confuse where to reply. Continue in a single thread.
(3,290 Views)
It's not supposed to be saved when you do this. First, you have to select either Edit>Make Current Values default or right click on the control and select Data Operations>Make Current Value Default.
(3,285 Views)
Thanks!-Please can you look at the amended attached VI. I am trying  to connect the two indicators to show the total number of over/undershoot values. In my test sample data that will be 1 and . How do I attach these indicaors to the for loop?
Kadeel
PS I do not know what a thread is. How do I stop repeating this message?
(3,275 Views)
A thread is to keep all the questions related to a single topic in a single place. To continue posting your queries in the same subject, just click reply button as what you did now. For a new topic, first search the forum and if not satisfied, then post a new message.
(3,273 Views)
Try this and post back if this is what you want?
(3,255 Views)
This post brings #20K posts to our beloved sir. Thanks a lot for your efforts and time. Please continue this help.
Mathan
(3,252 Views)
