save data into another array
Hello, I would like someone to help me with a problem I have in my program.
What makes the program is, for each iteration, take the data in "table iter" and saved in "output array." But in the second iteration instead of storing the results of the first iteration gives me "1" in the first five rows.
How I can fix it?
Thank you very much, Jaime
(4,107 Views)
Accepted by pescajaime
hi pescajaime,
  Please do the change specified in the attachments.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,089 Views)
Yeeeessss!!! thank you very very much!!!!
(4,074 Views)
ahhh, srikkrishnaNF you've made one little Spaniard very happy with a simple Shift Register. I'm suprised he hasn't given you a Kudos yet - I'm sure it will come.
Jaime - see how fast you get a response if you post in English not Spanish? Smiley Very Happy There's far more people who can understand to help you!
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(4,054 Views)
hi james,
  Thank you james,but atleast you should have given me kudos...isn't?Smiley Wink
Thanks and regards,
srikrishnaNF
Srikrishna
(4,026 Views)
Hi srikrishnaNF,
I held off on the Kudos because although you posted the solution, I had to open both VIs to look at them and look very hard at a large blok diagram full of orange to see where the changes were! A little bit of doccumentation on the block diagram pointing to you changes and highlighting them would have got Kudos from me.
(I'm hard to please, and I've still got no Kudos from any of the threads where I've got the OP to change and post in English instead of Spanish without using an internet translation engine. - I even posted a correct solution in Spanish and that didn't get Kudos from the OP. Just be happy that Jaime now knows about Kudos and you got one. Smiley Tongue)
James
(3,989 Views)
