save it to ms.word
From the Word document, it seams that you are using a graph from Excel not Labview. So you are probably doing things very complicated. Or you have made this document in Word/Excel, and not with a Labview program. You can get the bitmap from almost (if not every) Labview control/indicator by Labview program functions. On the other hand You are not showing any code, so it is impossible to help you. But that is your call
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 21 of 23
(1,036 Views)
i use report generation for make this graph that's word insert graph.vi.
so can you tell me how to give name to x and  y axis?
tanx
Message 22 of 23
(999 Views)
Hi marp84,
If your ultimate goal is to insert the graph from the VI you posted on the first page of this thread, then you may want to look into using the Append Control Image to Report VI instead of the Word Insert Graph VI. The Append Control Image to Report VI will take the image of the actual graph on the front panel (with x and y axis labels) and insert it into your report. Here is an example of how it can be used:
Thank you for choosing National Instruments.
Aaron Pena
Applications Engineer
http://www.ni.com/support
Message 23 of 23
(982 Views)
