‎04-01-2020 04:15 AM
i think he askes the same question but until now does not get any reply
‎04-01-2020 04:40 AM
‎04-01-2020 05:12 AM
Can anyone answer me with this mentiones above!!
‎04-01-2020 05:16 AM
‎04-01-2020 05:55 AM
He asked the question after accepting the solution, and no one answer him
I think it is wrong to don't accept the question as anew topic.
‎04-01-2020 06:13 AM
Hi BaJa,
I think message 8 in this thread, that I wrote and quote below, answers their (and your) question:
You can use the "Pattern" input to your List Folder call to limit the files that are returned.
In that case, "file-???.txt" or similar might work. You can use * for any number of any character, and ? for one character (any character), but the node doesn't support full regular expressions.
If the Pattern input isn't enough for you, you could try getting all of the files and then using something like Match Pattern or Match Regular Expression to see if the filename matched a more complicated pattern.
In your case, I suppose your pattern would be something like "Detector-???.txt" or similar.
‎04-01-2020 06:27 AM
‎04-01-2020 07:07 AM
Pattern input is ok, Now it is working
