saving this vi in 6.0
could anyone save this vi in LV 6.0
(3,047 Views)
I could do it if I had it in LV7.0 first
Waiting for you to save it in LV7.0
Julien
(3,030 Views)
I can't save it in LV 7.0,I found this vi in discussion forum and I use LV 6.0 I think this vi is saved in 7.1
(3,026 Views)
Here it is in LV 7.0
There were some (a lot) warnings while doing it:
BuildHelpPath.vi
Virtual Instrument
Cannot save VI from VI.LIB to previous version.
Check Special Tags.vi
Virtual Instrument
Clear Errors.vi
Virtual Instrument
Close File+.vi
Virtual Instrument
Convert property node font to graphics font.vi
Virtual Instrument
Details Display Dialog.vi
Virtual Instrument
DialogType.ctl
Virtual Instrument
DialogTypeEnum.ctl
Virtual Instrument
Error Cluster From Error Code.vi
Virtual Instrument
Error Code Database.vi
Virtual Instrument
ErrWarn.ctl
Virtual Instrument
eventvkey.ctl
Virtual Instrument
Find First Error.vi
Virtual Instrument
Find Tag.vi
Virtual Instrument
Format Message String.vi
Virtual Instrument
General Error Handler CORE.vi
Virtual Instrument
General Error Handler.vi
Virtual Instrument
Get Text Rect.vi
Virtual Instrument
Cannot save VI from a toolkit to a previous version of LabVIEW.
GetHelpDir.vi
Virtual Instrument
Longest Line Length in Pixels.vi
Virtual Instrument
ma_Check Waveform Timing.vi
Virtual Instrument
ma_Find First Error.vi
Virtual Instrument
ma_patchErrorCode or Caller as Source.vi
Virtual Instrument
Merge Errors.vi
Virtual Instrument
Not Found Dialog.vi
Virtual Instrument
Open File+.vi
Virtual Instrument
Peak Detector no State.vi
Virtual Instrument
Read File+ (string).vi
Virtual Instrument
Read From Spreadsheet File.vi
Virtual Instrument
Read Lines From File.vi
Virtual Instrument
Search and Replace Pattern.vi
Virtual Instrument
Set Bold Text.vi
Virtual Instrument
Set String Value.vi
Virtual Instrument
TagReturnType.ctl
Virtual Instrument
Three Button Dialog CORE.vi
Virtual Instrument
Three Button Dialog.vi
Virtual Instrument
Trim Whitespace.vi
Virtual Instrument
Waveform Peak Detection for 1 Chan.vi
Virtual Instrument
Waveform Peak Detection for N Chan.vi
Virtual Instrument
Waveform Peak Detection.vi
Virtual Instrument
whitespace.ctl
Virtual Instrument
Paulo
(3,020 Views)
Here you are...
Hope this helps !
Julien
(3,016 Views)
thank you very muchhhhhhhh
(3,000 Views)
