saving waveform graph continously
Hello everyone. i been working on saving waveform continously. What i mean is, if i run the vi for 5 minute, it will save the waveform from begining until i stop the program (5 minute). I manage to save waveform in format jpeg but the problem is everytime i save the image, it will overwrite the previous one. Is there anyone can help me?
Message 1 of 13
(5,639 Views)
Use a shift register.
Message 2 of 13
(5,637 Views)
When you are writing the jpeg file the filename you enter is the same that is why it is overwriting the file,
everytime you run the program.
As said above use the shift register or try different methods to name the file.
Shrek
Message 3 of 13
(5,626 Views)
I don't understand to use  shift register. At which part that i should put it?
Message 4 of 13
(5,616 Views)
hi
 do you want that once you stop your VI then it should save the image ? if yes then i think you should use event structure .
also see the attached VI of how to use shif register
regards
Regards
Message 5 of 13
(5,609 Views)
Is this what you need
Regards
Message 6 of 13
(5,607 Views)
Message 7 of 13
(5,603 Views)
Hi nolsqn, muks
Thanks for your reply.
Nolsqn, it will be pleaseure if you can convert vi that you upload cause i'm using labview version 8.5 :smileyhappy:
What exactly i'm trying to do is to save waveform from begining i run vi until i stop it. Let say if i run vi for 10 second, it will save 10 picture of waveform and it done  automatically. The vi that i attach here able to save waveform in format jpeg but it keep asking me to choose  the path to save the waveform.  I just want  it done automatically and does not overwrite  the  previous save file.
Muks, i try to run you vi but there was an error. I can't find function "IMAQ Write Jpeq file ". Is that because i'm using previous version of labview?
Message 8 of 13
(5,573 Views)
Don't worry about that function. It's from IMAQ and you do not need that toolkit. What you should be looking at is how the file name is dynamically created. Modify as necessary.
Message 9 of 13
(5,571 Views)
One of the method by which you can name a file without overwriting is by giving the current time as the filename.
It will create a seperate file as per time, check forum for the ex.
Regards
Message 10 of 13
(5,549 Views)
