scan from string
how do i extract the individual values and get them to display on waveform chart or thermometer?
i have no idea on how to format strings as there aren't many examples given. can anyone help me?
Message 1 of 23
(6,550 Views)
Hi Gekides,
you may try this:
That's just one possibility, there are multiple others...
Next time you should attach a VI with some data instead of those pictures. So we don't need to retype all the text in your receive buffer display...
Message 2 of 23
(6,516 Views)
those value won't be there all the time because it comes from Arduino and the Arduino isn't on all the time. Sorry. i will remember to attach the VI file
Thank you very much!!! may i ask how do i actually save those reading into microsoft excel? getting from http part 2(saving).png
Message 3 of 23
(6,315 Views)
Hi Gekides,
try this:
You need to provide a filepath to avoid the file dialog pooping up in each iteration…
- Why do you use the format string "%,;"  when your numbers use the point as decimal separator?
- Why didn't you use the array constant input for SpreadsheetStringIntoArray as I have shown before?
- Why does your IP address has a point at the end?
- Why don't you use the CleanUp button?
Message 4 of 23
(6,279 Views)
sorry but can you send me this VI
Thank you very much
Message 5 of 23
(6,252 Views)
Hi Gekides,
no, I can't - I didn't save it to my harddisc...
BUT: It's a snippet! And it's not that hard to recreate this with your own VI as starting point…
Message 6 of 23
(6,241 Views)
new body.pngHi this is my new program and somehow i can't seems to get the value out again. can you help me with it?
Message 7 of 23
(6,161 Views)
Can you attach your VI in LV2011?
Thanks.
Message 8 of 23
(6,150 Views)
sorry but i only got 2010. does this work??
Message 9 of 23
(6,141 Views)
Hi Gekides,
instead of putting pictures of your VI block diagrams into the block diagram of some LV2010 VIs you should use "Save for previous" from the File menu to downconvert your VI!
What should I do with some pictures? I'm not a painter…
Message 10 of 23
(6,137 Views)
