search function VI
Thanks for the sql statement. do you have a simple vi for me to try out the sql statement or can i just use my vi?
Message 11 of 31
(1,629 Views)
I don't use the toolkit but I would recomend testing the statement with the execute query function.
Message 12 of 31
(1,623 Views)
You can try just changing the string that you send to the "Select Data" VI, though I think Dennis is right in testing it first.
Message Edited by smercurio_fc on 07-14-2009 10:24 AM
Message 13 of 31
(1,621 Views)
Thanks for the reply. I will try it immediately tomorrow when i get to school.
Message 14 of 31
(1,619 Views)
Does anyone know what should be connected to the output of the execute query vi(recordset reference)?
Message 15 of 31
(1,602 Views)
Message 16 of 31
(1,598 Views)
sorry again. I've remodify my vi but after i run it, no data is displayed in the front panel. is it due to my sql statement or is it some other problem? My database relationship is below too. Many Thanks.
[IMG]http://i93.photobucket.com/albums/l65/vittoire/NewPicture1-1.jpg[/IMG]
[IMG]http://i93.photobucket.com/albums/l65/vittoire/NewPicture3.jpg[/IMG]
Message 17 of 31
(1,584 Views)
'WHERE OVID LIKE'? I thought you wanted to search for unit number. OVID is a key.
Also, please don't link to third-party image hosting sites. Just attach them or click on the 'Upload or Insert an Image' button.
Message 18 of 31
(1,574 Views)
sorry i didn't know that i could upload the image here. I have many different tab in the final part in my search functions which can allow user to choose what they want to search. the usercan choose to search by ovid, unit number, or mayb firstname. so now im trying out to see whether i can search by the unit number.
Message 19 of 31
(1,570 Views)
You can search by whatever you want, as long as the columns exist in the database. But you have to change your WHERE clause. Right now you have it hard-coded to be WHERE OVID LIKE, so whatever you put it it's going to match agains the OVID column. If you want to search for the unit number then the WHERE clause has to be WHERE unit ...  Also, why would you use a LIKE for the OVID column? I don't use Access, but I'm guessing that the bold indicates it's a primary key.
Message 20 of 31
(1,553 Views)
