Showing results forΒ
Search instead forΒ
Did you mean:Β
search string+data
Hi,I want to search some certain strings in data files.But I have no idea to do it.Who can show me some examples?Thank u very much.
(2,867 Views)
The modern way is to use Google desktop search. Old farts would use grep. If you want a LV solution then you do it in two steps.
Read the file into a string, use Read Crharacters.
Search in the string using match pattern found in the string palette. It’s really easy.
Yours Sincerely
John www.tradersmicro.com
(2,867 Views)
