searching a file in the disk
Here screenshots on how to implement the first option using build array:
And the true case:
Norbert
PS: Note that this procedure is only recommended for "small numbers of files to search for". Build array can blow your memory, so if dealing with lots of files, you should follow option 2.....
Norbert
Expert: Geometry
Message 11 of 18
(1,072 Views)
Hi my friend, How are you ?
This is what I did till now,
I'm waiting for your remarks and observations.
Cordially
IBN HAYANE Faiçal
Message 12 of 18
(1,053 Views)
Your code will most likely not work as you expect... did you try it?
Norbert
Norbert
Expert: Geometry
Message 13 of 18
(1,036 Views)
Yes I did, It works good, the only problem that I still have, in the result I got some empty boxes in my array !
I tried in vain the function "Delete from array" !
have you any proposition to do that ?
Message 14 of 18
(1,031 Views)
You only delete a single entry from the array.
The reason is that the "subset to delete" will only store one value. Reading the variable will create a copy of "subset to delete" sometime during code execution. So you will not know when the variable is read and what the value will be. This is called "race condition".
You have to create an array of indizes to delete.
Norbert
Norbert
Expert: Geometry
Message 15 of 18
(1,027 Views)
Thank you for your responsiveness,
Please have a look at my program as an attachement, it works but it needs something what I don't know !!
best regards
Faiçal
Message 16 of 18
(1,021 Views)
There are several severe flaws in your VI. I corrected them and put some style into it i ask you to keep for future work with LV.
Here you go, as mentioned, the one exception for this year....
Norbert
Norbert
Expert: Geometry
Message 17 of 18
(1,016 Views)
Thank you very much for your help. I have done some nice applications within LabVIEW, But now I feel really overdue.
Anyway, thank you very much, I'm very lucky to contact you.
Cordially
Faiçal
Message 18 of 18
(1,012 Views)
