separate the column in txt without space
hi,
i have a txt file which im able to read in Labview. i need to read the column and separate it accordingly.
0000014123B --> 0000 014 123 B (from single column convert to 4 columns)
Meaning to say, the input need to be separate into 4 different column as above. attached is the txt file.
Message 1 of 10
(4,014 Views)
Is it always 4 characters, then 3, 3, and 1?  If so, just use Substring.
Message 2 of 10
(3,995 Views)
Take a look at this
Randall Pursley
Message 3 of 10
(3,989 Views)
Hi Randall,
just slightly Rube-Goldberg… 😄
No need to build lines and remove the EOL, to finally put all lines with their EOL chars in a spreadsheet string. Just do it with one function… (Your version might be more memory efficient with bigger string arrays.)
Message 4 of 10
(3,973 Views)
Simple to use a loop to create dynamic search and replace strings based on an array of widths as well.
Message 5 of 10
(3,958 Views)
Hi Darin,
I really should learn RegEx someday… 😄
Message 6 of 10
(3,951 Views)
hi, thanks for the quick response. can i have the vi since i am new to labview and not familiar with the palettes. thanks
Message 7 of 10
(3,913 Views)
it's a SNIPPET!
Message 8 of 10
(3,908 Views)
hi,
i have created the vi as per in the image but i still cannot read the value.refer to the attachment. Can anyone advise me on that? thanks
Message 9 of 10
(3,871 Views)
Accepted by varsha88
Hi varsha,
- you forgot to enable the "Regular Expression" mode in the right-click menu of the parse function (did you notice the small star in the symbol?)
- you wired the TRUE constant to the  wrong input
- the second string constant should be set to \-code display mode (well, I guess there's a LabVIEW idea to show the display mode of string constants by default…)
Message 10 of 10
(3,867 Views)
