03-08-2010 02:34 PM
I am trying to read from a device that out puts core body temperature and heart rate. When I use hyperterminal the data displays as it should but when I try to read with lvterm.vi it looks like jibberish.
This is what it should look like.
I am not sure what is going on any help is appreciated.
IERengg
Solved! Go to Solution.
03-08-2010 02:43 PM
03-08-2010 03:00 PM
I have verified the serial port settings and unless there is an error in how the lvterm.vi inputs the settings, they should be correct.
4800 baud
8 bit
no parity
1 stop bit
no flow control
Thanks for the suggestion, if there are any other ideas keep them coming.
03-08-2010 03:03 PM - edited 03-08-2010 03:03 PM
Have you tried communication through Hyperterminal?
If so, do you get the same jibberish or the correct results?
Edit: Nevermind, I just saw your screenshot was from Hyperterminal. Let me keep thinking then...
03-08-2010 03:10 PM
I appologize the first suggestion was the correct answer. I did not hit the change settings button when running the vi. After I did all is well, thank you for the fast responses and my ignorance.![]()
03-08-2010 03:55 PM
IERengg wrote:I appologize the first suggestion was the correct answer. I did not hit the change settings button when running the vi. After I did all is well, thank you for the fast responses and my ignorance.
No problem. As I mentioned the type of garbage you were seeing isalmost always the result of a mismatch in port settings. Glad thisresolved your problem.
