show an image with 20Hz in pc lcd
amanver wrote:
or is my question not clear?
In the subject, you talk about 20Hz but in the body of the post you talks about 30Hz. What is it?
You also take about only one picture. Do you want to hide/show the picture with a certain frequency?
30Hz is similar is faster than a tpyical movie frame rate, so if it is just one picture, it will look pretty stationary.
A typical monitor refresh rate is 60Hz.
Message 11 of 13
(898 Views)
oooh.
excuse me. 20 or 30 has not difference, it is imprtant that frequency is user select.
Message 12 of 13
(887 Views)
When play back with Windows Media Play (ActiveX), you can set the frame rate.
George Zou
Message 13 of 13
(866 Views)
