10-22-2013 01:17 PM
Hello:
I am using Signal Express with a USB-6009. The attached sensor is a flow meter 0-5VDC output, scaled 0-5V to 0-500SLPM.
When running the software with no scaling, there are no problems. When using custom scaling, whether linear or map ranges I get flatlined readings at about 1 V output or 100 SLPM scaled output.
Any suggestions? Thanks!
10-22-2013 03:51 PM
