signal express voltage scaling problem
Hello:
 I am using Signal Express with a USB-6009.  The attached sensor is a flow meter 0-5VDC output, scaled 0-5V to 0-500SLPM.
When running the software with no scaling, there are no problems. When using custom scaling, whether linear or map ranges I get flatlined readings at about 1 V output or 100 SLPM scaled output.
Any suggestions?    Thanks!
(2,374 Views)
This is the LabVIEW board - a board for programmers. You want to post your question to the SignalExpress board - a board for users of a LabVIEW program.
(2,359 Views)
