smaller device driver
Is it possible to get a smaller device driver set, possibly just for the DAQ module I'm using without having to download and install almost a TB?
(3,200 Views)
Actually, about 10GB.... still a ton of data for one board...
(3,195 Views)
Maybe NI-DAQmx 9.8 Core Runtime if you need just a runtime version; less than 200MB
(3,178 Views)
The core is for deployment. You'll need MAX, the help files, etc. There is no such thing as drivers for individual boards and as you can see from the size of the core, most of the download is not the actual driver
(3,165 Views)
