solar cell crack
ok,can u please suggest me a solution for finding the defect in this cell,iam using labview 8.6,vission assistant 8.5
Message 11 of 16
(1,012 Views)
I already gave you a suggestion in message #2 - I can't give a solution as I don't use Vision (or the assistant).
Also I don't know what kind of defects need to be detected. What may work with your example picture might fail on a different kind of defect...
Message 12 of 16
(1,005 Views)
ok,thanq sir
Message 13 of 16
(996 Views)
what dubvlicate posts,if u have a solution suggest otherwise be quit
Message 14 of 16
(938 Views)
Hi number,
your duplicate post is mentioned in message #3 and #4. You got solutions over there, atleast you marked a message as solution!
What else do yu want?
Message 15 of 16
(930 Views)
ya I marked one as a solution,But its not working properly,so iam asking for some more solutions
Message 16 of 16
(899 Views)
