06-27-2012 08:02 PM
The "Position" property's outputs for these splitters (in the attached code) don't make sense. The splitters are not where the property says they are.
It looks like Property tracks the upper-left corner of TotalBounds. Is that right? How do I find out where the top of a horizontal splitter is on the Panel?
Solved! Go to Solution.
06-27-2012 08:59 PM
David, I believe you want "Splitter Position" not "Position"... See attached.
Charles Chickering
06-27-2012 11:41 PM
Good grief. I swear, some days you stare at the code so long it disappears.
Thanks for the help, Charles!
