splitting arrays
Hello everyone!!!
I have a problem: I have a huge 1D array and I need to split it in to sets of 8 elements as need to compare these 8 elements with another  1 D array of size 8. is this possible?
Thanks for the help!!
Message 1 of 23
(7,687 Views)
Try the Decimate 1 D array.  Read the help to see if it does what you want.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 23
(7,684 Views)
use the split 1-D array function in the functions palette
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 23
(7,681 Views)
Hello again.. But the size of my 1D array can be unknown and I wouldn't know how many sets of 8 I would have 2 divide it in to. What will  I pass in to the index input of the split 1D array function?
Message 4 of 23
(7,672 Views)
Two straightforward ways (among others):
  • Run a for-loop based (size of your array)/8 and then inside the loop use Array Subset to get each chunk of 8 elements. The comparison is done inside the loop.
  • Use Reshape Array to reshape your 1D array into a 2D array that has 8 columns. The number of rows would be (size of your array)/8. Then auto-index a for-loop to pull off each row. The comparison is done inside the loop.
Is the input array guaranteed to have a length that is a multiple of 8? If it's not, what are you supposed to do?
Message Edited by smercurio_fc on 05-07-2009 09:01 PM
Message 5 of 23
(7,664 Views)
use a for-loop
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 23
(7,661 Views)
 Yes the input array is a multiple of 8. thanks for the suggestions. ill give it a go:)
Message 7 of 23
(7,652 Views)
Still think decimating would be easier, but that's JMHO.
Here's why: (Assume N pts)
Decimate (add outputs until you have 8 outputs total).
Now, the outputs will be 8 size N/8 arrays.
Next, concatenate them back together.  Now you have a 2-D (8 x N/8) array.
Transpose it if you need it the other way around, and you're done.
-Matt Bradley
Message 8 of 23
(7,639 Views)
True, but using Reshape Array allows you to do the same thing without having to hard-code the dimensions (i.e., the size of the Decimate and Build Array functions). The inputs to Reshape Array can be calculated using Array Size and the Quotient & Remainder function. More scalable. Smiley Wink
Message 9 of 23
(7,599 Views)
Hello smercurio,
I am usind the Array subset to split my huge 1D array in to chunks of 8. But I am unsure as to what to pass in to the index input of the Array subset function. When I put it in a for loop, the index continuously changes. So what do I input?
Thanks!!
Message 10 of 23
(7,578 Views)
