start at 100 and subtract 10 filling an array in a for loop?
HI i'm having a brain freeze can someone tell me how to fill an array in a for loop so it has 100, 90, 80,         70 etc - this is so simple but i'm having difficulty initialising the array and building it with shift register etc
Message 1 of 9
(3,601 Views)
As you stated, store the current value in a shift register.  Inside the loop subtract 10.  Have the results autoindex out as well to build the array.
Message 2 of 9
(3,586 Views)
could you post an example? as a VI or screen shot? I could do this in an instant in Python or Matlab  - but i have control of variables very easily and I just can't get my head into Labview!!
Message 3 of 9
(3,584 Views)
Accepted by charliejeynes
How this reads: Do my homework for me!
This is super basic and any example I can come up with will give you the answer.  If you know how to use a shift register and how to autoindex an output array, you can do this.  The wires are the variables, so you have full control over them.
Message 4 of 9
(3,573 Views)
"Ramp Pattern" is a polymorphic VI. Select the "Ramp by Delta" flavor.
Wire "-10" to the delta "100" to the start, "0" to the end you are done.
If you are required to do it the hard way a For loop with a "11" wired to the "n" and then subtract "10" times the iteration terminal from "100" and wire to an output tunnel.
Ben
Message 5 of 9
(3,567 Views)
you may be interested in
"http://zone.ni.com/reference/de-XX/help/371361J-0113/lvanls/ramp_pattern/"
EDIT: Ups, Ben was quicker than me
Message 6 of 9
(3,564 Views)
it is super easy when you are familiar with all of labviews peculiarities -
for anyone interested I did this
Message 7 of 9
(3,547 Views)
Are you sure you want the For loop to run 100 times?
Message 8 of 9
(3,519 Views)
The "etc." poorly defines the problem. Do you want stop at zero? At 60? At -1000000??? What do you want the final array output to be?
And yes, I would do something similar to what Ben suggested.
Message 9 of 9
(3,498 Views)
